- Oct 16, 2017
I do a lot of production runs on the lathe. After several hours, tool changes can be tiring. Also tool changes close to a spinning chuck can be dangerous with tired hands. In addition I have a mix of US and Asian holders with different size lock nuts. I needed a better way to grip the holder and a standardized elevation lock nut.
These are made from 416. They swallow the entire post and can be locked using fingers on the knurl or a 6mm Allen key. The Allen key interface is a 12x1.75 grub screw run to bottom and backed up with red Loctite.
