There are a few of us. I have had a 770 series 3 since December, 2011. I bought mine with the stand, the flood coolant setup, the jog shuttle, the TTS system and the Tool Assistant. I also bought their computer and SprutCAM and the 4th axis. I did not get the power drawbar, the ATC, or the full enclosure. I also provided my pwn monitor, mouse, and keyboard
If I had a choice, I would go with the 770 over the 440. It's much more machine. Larger work envelope, 33% more horsepower, more mass.
As to the good, the bad, and the ugly, Tormach has had some problems. I suspect that is true of most machines when it comes down to the nitty gritty. Many of the issues that I have encountered along with some fixes are documented on this forum. From what I have seen on other sites, the PDB and ATC have some issues. I have neither so no problem there. My Tormach computer was defective from the start and To4rmach replaced it. I had to replace my spindle cartridge early on due to a bearing failure. The replacement cartridge had a runout issue that most likely would have been corrected during machine QC had it been installed on a machine. There were some shady electrical connections that shouldn't have been. I have had to replace a failed capacitor in the coolant pump and a failed fan in the cabinet. The OEM homing system is not very accurate and I added an optical homing system to my machine.
The Tormach machines are not in a class with industrial machines but that said, there are dozens, if not hundreds, of users who are successfully using Tormach machines for every day production work. On Facebook, there are two groups, Tormach Users, and Tormach Opera6tors, where you will find a lot of shared experiences. Tormach machines, IMO, will not hold sub thou tolerances routinely. However, the owner of a local CNC job shop who had more than twenty years experience as an aerospace machinist had told me one time that he would not guarantee hold tolerances better than +/-.002". (He did on everything we had him do but he wouldn't guarantee it.)
