- Mar 26, 2018
- 2,724
Sounds like a good plan.I'm only concerned with the Lathe. The other 2 machines are on small VFD's as I want the variable speed and do not have all the start/stop needs of the lathe and it's wiring. I was contemplating a re-wire of the lathe but believe I will make my life hell trying to wire in all the braking and direction changes needed in typical machining. The hand switch on the carriage also scares me - that I'd lose that function.
The relays and switches internal to the lathe presumably work already - feeding "simple" 3 phase and using the existing wiring seems to be the most straight forward solution. At this point it looks like a rotary or (most likely) static or digital converter is what I should have gone with (already have the VFD on order, so I think it'll go back).
In hindsight, if I had seem my collection of 3ph tools growing like it did - I probably would have invested in a rotary converter in the first place.
I will say that you absolutely can keep all the original switches, including the start/stop lever on the carriage. I have done exactly that. Basically you rip out all the existing wiring and bring all those switches back to the VFD as digital inputs.
Keeping the lathe as-is and going to a phase converter is perfectly acceptable as well.
