1. I wrote a LibreOffice Write document with an equation in it; selected the text and the equation; copied it; then pasted it here: (I am trying here, since I could not do the following at the other site)
This is a little test document to see how much of it can be posted at LinuxCNC.
Equation with Greek letters:
2. The equation does not get pasted.
3. Next, I used Greenshot to select an area of the document containing the equation, capturing it as an image; pasted it below: (SUCCESS ! I can express arithmetic and math concepts in a tidy way. Thanks, hobby-machinist.com)
4. The equation shows. Good.
I had to convert the file to a *pdf in order to upload the file.
I tried to post this as a test at LinuxCNC.org, but could not.
I will post this here, then see if the attached *.pdf is available.
