- Jan 22, 2020
- 42
Guys,
On my Craftsman 101.07301 the countershaft shaft...….the actual shaft with the 4 flats milled on it [ M6-75 ] has metal worn away. The shaft corners where the two flats meet, are worn from the screw dragging across this corner, when rotating the shaft to tight / loosen the belts. The corner is no longer a sharp corner, but grooved in the shape of the screw end.
Wondering...….is this hardened steel?
Can I just tig the groove to fill it up, and file smooth / back to shape?
Not being sure what the metallurgy of this part is...….this repair may fix it, or make it softer...….hummmm.
Thots please?
Thots please?
