Can youi hear me now? Wolo Air Horns for Harley Dyna.
Zigeuner
I've always enjoyed having a nice loud horn on my motorcycles and cars. In fact, I have air horns on my Dodge Dakota and my Ford Escort. They are useful in waking up other drivers. Whenever I add horns to a car or bike, I always leave the stock horn or horns in place. I add the extra set of air horns with the matching compressor and provide a second horn button, just above the regular one.
My rule is that I can bolt or clamp add-on items to the motorcycle, but there is to be no cutting, grinding, drilling, gluing or other disturbance to the original equipment on the bike. Sometimes you may wish to move or change items and it's not nice to leave ugly holes in the metalwork.
This particular motorcycle, the Harley-Davidson Dyna Street Bob, is rather close-coupled and doesn't have a lot of room to add things like horns. After some thought and discussion (with myself, LOL) I determined that the only possible place was on the left side, under the saddlebags.
I removed the two 3/8-16 bolts securing the left passenger footpeg bracket to the top of the swing arm and took measurements (holes on 1-1/4" centers). I then built a stainless steel crutch to mount to the two holes to hold the FIAM compressor and the two Wolo trumpets, a 10" and an 8". I think they sound a fifth note apart. They are rated at 130 db but I can't be certain. In any case, they are hellaciously loud. The crutch is TIG welded together and simply bolts on.
The horns are tucked up under the saddlebag are out of the way and won't touch on a fast corner (I've been riding motorcycles for many years and I don't do fast anymore, LOL).
I just got the horns and compressor mounted today. Still to come will be the addition of the extra horn button from my old bike and the relay. I will run 10 ga. wires from the battery and ground. The positive goes to the relay and the ground goes direct to the horn terminal. The horn button grounds the relay so that it will pull in and operate the horns. With the relay and the trumpets set very close to the compressor, the operation is instantaneous.
These are particularly useful when coming to a corner where there is a car waiting to pull out in front of you. It will definitely get their attention. If that doesn't work, I will generally apply the brakes and prepare to evade the car.
So many people nowadays are doing things that they shouldn't be while driving. They do their makeup, comb their hair, tie their ties, text their friends, talk on their cell phone and so on. I even saw a guy reading a book while driving the other day. He had it propped up on the steering wheel. I didn't get the title, but it must have been good. Reading is good for your mind but poor for your driving record.
Wolo also makes one called the "Bad Boy" which is a small combination air horn unit with two short trumpets. It's compact but not loud enough for me. Hope you like the horns. Everyone who rides a bike should have supplementary air horns.
Some drivers are so deaf that an air raid siren would not work! -^^
I have added horns to my cars over the years and changed out the beep beep horns that my bike has as well. I have not gone to air but have looked at them many times.
Over half the crashes between bike and car is the car turning left in front of the bike. Car driver says "I did not see the bike" which is a load of ...... They are just too full of themselves. Been riding since '82 and do not trust any of them.
author=pdentrem link=topic=3294.msg23738#msg23738 date=1314702618
There are two accident scenarios on motorcycles that are generally fatal. One is where a car is going to pull out of a road from the right. The other is where a car is going to turn in front of the motorcycle.
In each case, the wise motorcyclist will watch the wheels of the car. Due to the movement of the motorcycle and the problem of parallax, if you just watch the body of the car, you may not see it begin to move.
What I have done for many years in such a situation is to focus on the front wheel of the car that is visible to me. You can see the contact patch. If the wheel start moving, you must take evasive action instantly. That would be, slow down, brake, move away from the hazard.
A horn won't necessarily save you in such a situation, but it can help to make the driver wake up.
By the way, I did a test on the Wolo Air horns. I drove a block away and parked. I had my wife press the horn button. I could hear the horns fromi inside the car with the windows closed. That will at least wakt them up.
The air horns are the only way you will ever get enough force. All of the electric horns are below 100 db, as far as I know. Most of the air horns are over 100 db and some up to 120-130 db, more than 100 times louder if I recall the formula correctly.
Happy Trails! :)
There are two accident scenarios on motorcycles that are generally fatal. One is where a car pulls out of a road from the right. The other is where a car turns in front of the motorcycle.
What I have done for many years in such a situation is to focus on the front wheel of the car that is visible to me. You can see the contact patch. If the wheel start moving, you must take evasive action instantly. That would be slow down, brake, move away from the hazard.
By the way, I did a test on the Wolo Air horns. I drove a block away and parked. I had my wife press the horn button. I could hear the horns fromi inside the car with the windows closed. That will at least wake them up.
Happy Trails! :)
I have air horns on two of my bikes and a boat horn on the cruiser (no room to hide the hardware). I have just mounted air horns in my car, but haven't wired them yet. The only trouble is that I've been nearly side-swiped twice by women drivers who kept coming after the 112 dB sounded in their ears. They both just waved their hands as an "oops".
Seems to me that the natural reaction to a loud horn when you've started a questionable action is to reverse the action and go back where you came from. I guess the imperative of being in that lane trumps letting others live.
author=Hawkeye link=topic=3294.msg23826#msg23826 date=1314751779
I've been all over California, Oregon, Arizona, Colorado and New Mexico on various motorcycles. I can't even list all of the times that my air horns have saved me from getting rolled out. They are particularly useful when a driver on one side or the other will move over into your path without signalling, let alone even taking a look.
Happy Trails!
