These are a couple of carb cable adjuster I made up, makes syncing the carbs a little easier. The adjusters were from 8mm rod, turned down to 6.37mm mm and threaded 1/4" UNF for 40mm. They were drilled through with a3mm hole for the cable inner and the top section enlarged to 5.5mm to take the cable out, then knurled using a scissor knurler I made years ago.
The aluminium brackets are very small, so very difficult to polish. I may anodise these layer.
I still have to fit a locknut to the adjuster, to stop movement.
