- May 3, 2017
- 1,997
Sounds like you're one step ahead of me again. About 4:00 this morning, I thought about making sure you were careful to look for a flat spot on the fender. Always safe to not cut until you're sure. Again, not being familiar with Ford, I can't say much about their rubber grommet, but that simply wouldn't work on either of my Chevy's. The curvature of the cab in the original position is way too acute to allow it to be used on the fender. What you've done looks good, and it works. Like Yogi says, "If it ain't broke, don't break it."I looked pretty hard at putting the fill cap in the back of the fender, but had 2 issues...
First, I have a bed crossmember in the way... I would have to run the fill hose through it, or relocate the crossmember... either way, it is doable, but the other issue is that there is not a flat area on the fender anywhere, and I'm not sure I could trim out the fill neck on a curved surface and make it look anywhere near acceptable. A rubber grommet like the one used to seal the original neck in the cab corner may work... IDK. I'm going with what I have for now... if it doesn't work out, it will be fairly simple to patch and repaint over the hole in the bed and try something different.
The current filler neck setup is very similar to what was originally used on the panel trucks... it was fairly low, just over the top of the frame.
-Bear
Regards,
Terry
