When I say riser, I'm talking about clamping it to my mill table to hold odd shaped parts. It's cheap so I can drill holes in it without a thought.what kind of mill? That doesn't look thick enough to push it hard. My mill is a lot thicker and it's a Clausing .. so while it might do well for a small mill, I would be careful about overloading it. As far as what it was.. no idea... I hope it works out for you.
ok, I was referring to a riser to raise the head of the mill. There are risers for BPs that fit between the head dovetail casting and main mast.. so it raises the entire head up.When I say riser, I'm talking about clamping it to my mill table to hold odd shaped parts. It's cheap so I can drill holes in it without a thought.
I'm a bit confused about what you are imagining I'd use it for.
