I've read a lot of information on cast leadscrew nuts (moglice, various epoxy/teflon/magic dust recipes). Many people have made their own to what sounds like great success, with little or no backlash because of the casting directly to the leadscrew itself. After doing the math, substances like Moglice, while expensive, amount to very little actual cost per nut. I can find no obvious issues with wear. I'm well aware of the issues with machines solutions such as anti-backlash assemblies machines from various brass pieces that can manually tightened and calibrated. I've done plenty of casting of resin, various epoxies before and it is hardly difficult for a hobbiest with some patience. I currently abuse Sherline equipment and deal with the anti-backlash solutions for that often My system runs manual and under custom CNC control and I have plenty of correction for backlash. It brings to mind a question:
If cast leadscrew nuts work so well, and are not that expensive, why aren't they more common or standard issue?
