I'm resurrecting a conversation I had with, largely, myself last winter; it ended inconclusively when COVID heated up, so now I'm back, seeking advice. There is very little discussion here of using CBN grinder wheels instead of AO for grinding HSS lathe cutting tools. I had a bunch of correspondence last winter with Ken Rizza of Woodturnerswonders; he was very helpful.
My thought process is that I have a very small shop that functions as a part-time office and the core of my vintage fountain pen restoration business; my Logan 820, bench vise and 6" DeWalt bench grinder are in here too. When my adult daughters were children it was their bedroom; it's around 11x10.
While it works really well as a shop most of the time, dressing a 80 grit AO wheel just destroys every semblance of anti-grime I'm able to achieve. Pretty crazy, and stupid, to see that needing to periodically dress the grinding wheel is keeping me from the grinder.
I've been able to deal pretty effectively with the hot metal dust thrown off in normal grinding -- a friend and I made a box from steel that bolts to the rear of the coarse wheel's cover, catching all the dust except what goes straight down. That stuff I catch in a wet paper towel on the base. I've tried vacuuming the dressing dust but it just flies everywhere and leaves a dust layer throughout the room.
So, I'm considering CBN, admittedly first to never have to dress a wheel again, but also for its other major advantages -- smooth grinding, maintenance of size and shape, and the quality and sharpness of its results. Yes, it's dear for a grinding wheel, but it also lasts forever and at $170 for the 8" wheel isn't out of reach. Is it my only alternative? I could in theory get a belt sander, but really don't have the space for it. The bench grinder is bolted to a bookshelf...perfect fit, perfect height, enough headroom. Believe me when I say that I just do not have the space for a separate floor base. I don't know of another alternative. I guess I'm thinking out loud here...and looking for general thoughts, having learned from the wide range of views expressed here.
Also, specifically, whether there are any issues with installing an 8" wheel on a 6" grinder; the correct bushing comes with it.
And, are there any issues with mounting a 1.5" wide wheel? The standard Norton is .75".
Finally, for cutting HSS, generally M2 but also some harder stuff, would you recommend the 80 or the 180 grit?
Many thanks,
Tim
Many thanks,
Tim
