Center drill options
martik777
Apr 19, 2011
1,138
Is there a alternative to those fragile center drill bits? I'm drilling for a 7/32 hole in 1018 on the mill and the tip sometimes breaks ruining the part. I'm running about 600rpm with with a drop of oil. Center drill is about 1/4" OD
Or use a larger size center drill, just use the point as a spotting drill, no need to go full depth. Another option wuuld be to use a screw machine length drill, they are shorter, stiffer, and able to spot the hole without skateing around.
Spotting drills are stiffer than screw machine/stubby bits: the flutes are shallower since tge don’t need to remove a high volume of chips.
Centre drills while used all the time for spotting holes are really not designed for this purpose.
I have had excellent luck with only a couple of sizes of spotting drills so not a big investment.
You really don't need any more than a small divot the width of the small diameter. That cannot possibly cause a breakage.
One of two things is happening....either your part is moving or your letting the chips build up.
You can run that center drill a little faster but look for chips build up and a dull tip.
These are easily sharpened.
