4
4GSR
Forum Guest
Register Today
As for the bearing preload being too tight or not, as long as that part of the housing does not run hot, I wouldn't worry about it. IMO.
Another thing I learned from reading all the manuals is that the worm and worm gear and the half nuts on the back side of the apron do not get lubed unless you do it manually. They are not in a particularly easy place to get to. You can use a light grease like NLGI 1, or way oil, on both the worm gears and the half nuts. I use either one, but it is important to lube them regularly, or they will fail. My Kent lathe came with spare worm and worm gears, and an extra set of half nuts. I wonder why???
AW32, AW64, etc, are hydraulic oils with anti wear additives. There is also plain hydraulic oil, without the additives. Hydraulic systems have submerged gears, bearings, and sliding surfaces. Gee, just like a lathe... Hydraulic oils also have additives to stop cavitation, and to keep the oil from breaking down. It is also quite inexpensiveHydraulic oil. Is that what you mean when you say AW?
