Guys I need to make some small knobs for my band saw so I am trying to come up with a plan to keep it simple.My first thought was to take some 5/16 bolts 1" long and turn the heads round then apply some knurling.But after turning the head round it will be just to small.So my next ideal is to purchase some all thread rod and just cut several pieces 1" length.Next would take some round 5/8 rod do the knurling then drill tap a blind hole,just cut each knob to length and start over with the drill/tap.I would take the 1" length threaded rod and screw it into the knurl knob.Now my problem is,should I use epoxy or lock tight to keep the all thread from coming unscrewed from the knob.The knob setup is just to keep the another part from coming loose,such as the thrust bearing so its not going to be wrench tight but hand tight.McMaster-Carr does make these knobs at 11.00 ea but that's no fun.Here's a link to what I want to make
