Hi all, trying to cut a 1/4" slot in a garden tractor axle, think it's 1037, 1055, 1541, don't know for sure.
Anyway I'm trying to do the math. Could someone take a look and see if I did it right. Thanks
I'm a little confused by your calcs, but if it IS a 1/4" (.250) cutter and the shaft is not hardened:
(80x4)/.25=1280 rpm
Being of unknown material, maybe dial it back a few hundred rpm.
Mathematically 266 is closer.
Personally I would try both and see which one is best. I probably would experiment slower and faster as well. I like seeing things for myself. I'm weird that way...
Don't overthink it. There is an old expression "Paralysis by analysis".
