a couple of thoughts / questions here. just got in a grizzly g0704 mill. did the spindle break in last night and was
checking things out, cleaning the machine. the vertical face of the dovetail way on the front of the milling table
seems to be finished a bit poorly on my mill. the dovetail on the bottom where it interlocks with the saddle.
looks like it wasnt ground, or something. i tried placing a dial indicator
with magnetic base on the top of the cabinet and running the table past it to check flatness, has a bit of variation. also,
over the entire length of the table motion, it seems to have about about 8 thou (.008) runout if thats what you would call it.
its like the table is bowed? i did have to disassemble the table to move it down stairs so i wonder if i reinstalled the gib wrong?
checked it a bit when it was off the mill and mostly looked okay, lightly stoned it and scrubbed it down.
did i get a dud table? i'm pretty new to this stuff, so any recommendations on how to better check the alingment of these parts?
i can post some pictures later, but was wondering if others had experience with these mills, how theirs was finished particularly.
thanks
-eian
thanks
-eian
