I have some threaded chucks here that I'm trying to fix up to use. I'm planning on turning the arbors on the lathe. I'll likely single point the threads to keep them more concentric & hopefully less runout. I know in the end it is just a drill chuck & some runout is a given but I need practice at thread cutting anyways.
The question is are you picky what your arbor is made of. I use a bunch of mystery metal from the hardware store. Some of it doesn't turn very well but I have some that is very soft & does turn well. I have others that I have marked as mind steel that I've just picked up here & there. It isn't as soft but is still somewhat soft & turns well. I was thinking of ordering drill rod for this but thinking more on it it seems that soft metal would be better for this & starting with a ground surface would be almost pointless if I'm turning it.
My Morris taper arbors seem to be quite soft.
