Chuck Key
Charley Davidson
Nov 8, 2011
1,678
I wanted another chuck key for my 4 jaw after watching a Tubal Cain video on indicating a 4 jaw so I made one last night, I still need to make the t handle.
First I chucked the stock in my 4 jaw and indicated it in, then pushed the tailstock with live center up against it and turned everything to size. After the lathe work was done I mounted it in my Kurt and milled a flat on the top side then rolled it 180 and milled another flat. These flats were for indexing for the square end that needed to be milled since I don't have a collet block. They also made drilling the hole for the T handle easier. After I milled the second flat I did the arithmetic and started milling the first flat for the square end, rotated it to set on the other flat and milled the opposing flat. Then I turned it 1/4 turn and indexed the first 2 flats I milled to the jaws, rolled it 180 and repeated the process. It's turning out nice
DSC00466.JPG DSC00467.JPG DSC00468.JPG DSC00469.JPG DSC00470.JPG DSC00471.JPG
Nice job Charley, I made most of mine the same way except I had a 5C Collet Block.
Paul
Been wanting a collet block ever since I saw the first one but had no use till I got my mill, now I can't afford it. Gotta go get a job, can't seem to stretch $179.00 a week past 2 days:headscratch:
looks nice!
having 2 keys sure makes indicating a breeze...
nice job charley
having 2 makes centering the 4 jaw a lot easier
steve
Finished it last night, turned out nice thanks to Paul Hicks who gave me a set of reamers, Made everything come together nicely
Can't wait to use 2 keys tonight:biggrin:
Looks good. Who needs a collet block? Just using your head seems to work well.
Benny
