Hey Guys,
Pretty sure most everyone has run into this sometime. I have an old SB9c used solely as a hobby lathe. It has an old Cushman 5-inch, three jaw. Seems quite a bit out there. I check the lathe alignment and tweaked it a bit, then check the runout of the chuck on a piece of 3/8 drill rod. I got about .006. I pulled the chuck apart, and cleaned it and check the runout of the mating surface of the backplate and got about .003. Took a skim cut, and re-checked and got .0005. Put everything back together and rechecked the drill rod. Now I'm around .010. When tightening the chuck, it does not look like all three jaws are gripping equally. I loaded up the outside jaw set I have and got around .003 runout. I also noticed that the three digit number on the jaws do not match that which is on the chuck.
1. What are my options?
2. Can the jaws be replaced?
3. Has anyone successfully ground their jaws on a SB9?
4. Is it safe to use the outside jaws to grip inside?
5. Should I just live with it?
6. Should I just buy a new chuck?
Thanks a lot for the insight,
Greg
Greg
