Chuck Question For Colchester Lathe
C
Cabro32
Forum Guest
Register Today
I have a Clausing Colchester 15" X 48" Lathe that came with a 9" Burnerd 3 jaw chuck. I want to buy an independent 4 jaw chuck. What would be the optimum size chuck to buy for this lathe.
If it were in my shop, I'd put a 10 or 12" on it. It depends largely on what you intend to do with it. Of course, the larger the chuck, the deeper/longer the jaws are.
Cab, I put a Bison 10" 4 jaw on my Clausing 1300 (13" swing) and glad I did. With a 15" swing, if I was planning on buying only one 4 jaw, I would not go smaller than 10" and would consider a 12" according to weight & whether I thought I alone could handle it. At some point, weight may determine whether you'll need one of those "over-arm" things I can't think of the name of, to suspend the chuck from to mount & dismount it.
I kind of go on the theory that bigger lathes draw bigger work and bigger work needs a bigger chuck.
Thanks Tony and Amigo for your help. I was leaning toward a 12" and you made it unanimous.
Joe
pdentrem link=topic=748.msg4092#msg4092 date=1297166835 said:
Are those cars yours?
.....Yes
OOOOO I am jealous. Wish I had them! 8)
