- Jul 28, 2017
- 2,393
I'm using a diamond grinding wheel mounted in my 4" angle grinder to flatten the top of a large hunk of basalt that was used as a support pier for our old barn. I want as much contact area as possible but it's proving to be challenging to get the contact area both flat and in the desired plane (perpendicular to a vertical stud-to-be-sistered-in). I had the thought of attaching a circular level to my grinder to make that easier, but I'm wondering if the grinder vibration will cause problems with the bubble, perhaps shaking it up into a froth. So my question is if anyone has tried this, and, if so, how it worked out.
The (HF) grinder has a handle that can be screwed into either the left or right side of the tool, so I had the idea of using the unused hole to attach a bracket that holds the level. I can bend/rotate it to get the level's "0" parallel to the diamond grinding wheel. Sounds pretty cheesy but hopefully the results will be better than eyeballing it with my AMD-affected eyes. That's the idea, anyway.
