- Dec 18, 2019
- 6,525
The manual isn't clear, at least to me. The typical connection looks incorrect in Figure 4. They have the collector of the NPN photo-transistor connected to the negative of a battery and have labeled it as COM-. The emitter seems to be the alarm signal. That would mean the collector is connected to positive and ALM would go to a load and then to ground. So I'd guess that the label should be COM+?
Anyone used this signal before and figured it out? I'm trying to work through a cable diagram for my ELS and wanted to add in this signal into the cables I make. I am not using the alarm at the moment, but when I button things up in a box, I would like the controller to be able to read this signal, since the little light will no longer be visible.
Figures 7 & 8 don't make much sense either, they don't seem to make sense with reference to Figure 4.
Can someone point me in the right direction?
