[4]
Clausing 5914 - Cracked Brake Rotor on Counter Shaft - Fixes?
[3]
[10] Like what you see?
GrizzlyBagWorks
Newbie
Jun 23, 2016
15
Likes
14
#1
I'm getting closer and closer to getting my 5914 rebuilt and back together. I'm finishing up the countershaft rebuild/bearing replacement and have found that the "rotor" that contacts the brake shoe to stop the spindle is cracked on the back side. The crack doesn't run through to the front but it has left the face of the rotor concave.
My first choice would be a OEM replacement but I doubt I'd be able to find one and know I couldn't justify the cost from Clausing if they even had it.
I'm considering attempting a repair on this. My thought here is to V out the crack, then braze it. Throw it on a mandrel, face off maybe a 1/16" so it's flat and then use a 1/16" spacer on the backside maintain overall depth since the assembly is held in place with circlips.
Other option is to purchase a 4" cast iron round and remake the part (~$60+shipping). Do i need to worry about balancing this component, like the original, if I go this route?
Curious to hear your thoughts on this. Thanks guys!
RandyM
H-M Supporter - Commercial Member
Staff member
Apr 12, 2011
2,356
Likes
2,313
#2
The short answer is, Yes it has to be balanced, particularly if you are going to run high RPMs.
Why did you discount buying a new one before even checking it out?
benmychree
John York
Jun 7, 2013
2,756
Likes
1,994
#3
If you make one from continuous cast iron rod, it may not need to be balanced; that breed of material is likely to be more homogenous that the original, which was likely a sand casting.
markba633csi
Apr 30, 2015
3,067
Likes
1,586
#4
I would try to repair it, you have little to lose- afterwards you could make a home-brew balancing jig, probably get it pretty close
Mark
machPete99
Active Member
Dec 12, 2016
111
Likes
59
#5
I may have what you need, see PM.
[6]
[5] [7]
