- Sep 29, 2010
- 1,558
I picked up this 10" Frankenlathe in a trade about 3 years ago, And it had some problems and still does. But having all three of my Lathes down I needed to do something cause it sucks not to have one running.
The plate behind the dial that is bolted to the compound was tilting to the left when i move the compound. I took it apart and found that the allen bolts was pulling through the whole.
Only way to repair it was drill it out thread it for a 3/8 bolt and drill them for a 12-32 bolt.
Then I cut them off at the back,Front and back repair.
I didn't have any allen bolts that size so I just used screws for now. I had a bunch of nos. parts I got off ebay so I new I had some thrust bearings for a H10 Tapper attachment.
So I used 1 washer and 1 bearing on.
Got it back togather and it was still hard to move so I looked at it again.I found that one of the jib screws was missing, So i made one out of a 1/4 bolt.
I got it back togather and it works ok but still needs some work.
Paul
Paul
