Just as the title says, anyone know the correct fuse size for the power feed that was an option on the 8530s? I thought I'd try here before contacting Clausing.
Brian, I have an 8520 with a power feed on the x axis and the fuse has this on it. 250V Buss AGC 3A.
Not sure if this is a stock item as I have only recently purchased the mill. All seems to run well. Hope this helps.
David
