- Apr 24, 2021
- 462
I had a very large part from a machine at work that I had to turn. It was a large cylinder that had brake pads around it. The pads had glazed and scored the surface of this cylinder. I took a total of .050 off. I would estimate it was 8 inches in diameter. The metal seemed like iron but I am completely guessing. I took doc’s about .010-.015 until I needed a nicer surface finish. While turning it didn’t come off as chip, rather a powder or granular consistency resulted. This got on the ways, I’m the hand cranks, and even obstructed my oiling port detent balls. My question is, should I take apart the cross slide, compound, and tool post to clean out this sand like chips? I attempted to cover the ways, but it threw this stuff over the entire length of the lathe. It is a Chinese pm1236 and I know they aren’t known for lasting the longest so I am trying to maintain the best I can.
If anyone can give their input on wether iron leaves a sand like chip when turned, or if that’s how steels that are hardened behave it would be appreciated. I have turned ar500 plate before and it behaved similar, but this part was much easier to turn than the ar500.
