Close up pictures of the PM-1440GT foot mounts
azonin
Mobilis in mobili
May 15, 2019
12
Could anybody who owns a 1440GT post a few close up pictures of all 6 areas in the base where the feet mount to, please? I'm trying to figure out if I have enough room to use the Footmaster leveling casters with the 90mm x 90mm plates that have 4 holes in a rectangular pattern spaced 70mm.
Also unclear if there are just single 1/2-13 Whitworth threads for each caster, or if there are additional holes for square mount pattern already there as well. Any clarifications would help.
Thank you
Here are some pics of a 1440GT with the PM-supplied leveling system.
I also attached a PDF of the base dimensions, including locations of the drilled and tapped holes. The PDF is a scan out of the paper manual prepared by the manufacturer that came with the lathe. I have not verified the dimensions, but can do so if you like.
HTH, Bill
Headstock End from Rear Corner
295578
295579
Headstock End from Side
295580
Tailstock End from Front Corner
295581
Tailstock End from End
295582
Tailstock End from Rear
295583
  • 1440GT Stand Layout.pdf
Try 1/2-13 single stem Footmaster casters. I have used them on a bigger lathe (RML 14-40) without problems and plan to do it again on the eventual-to-arrive PM 1440GT.
Ed
HTH, Bill
Thank you very much, this is very helpful!
Ed
Which series did you use? I have a collection of GDR-80 and GD-100. Could get the 120 or even the 150 versions, but most likely an overkill. The 100 version I have now are plate versions, and the 80 are stem. So before buying more I wanted to use the ones I already have.
I would go with the polyurethane pad, my only concern is that there can be some settling/movement with rubber/plastic pads. Polyurethane pad should be more stable. the 80 series is rated at 1100 lbs per wheel.
I get the PU wheels and pads whenever I can, especially for the heavier loads. The ratings on these casters aren't very scientific. When you visit me in a couple of weeks, I'll demonstrate. I'm leaning towards using the 80 series, as the ones I have right now do have he PU wheels and the built in ratchets. I used 100 series on my Tormach 1100 CNC mill, which is loaded to about 3000lbs, with no issues.
On mine the machine base was threaded 1/2-12 and needed to be chased with a 1/2-13 tap.
