- Jun 27, 2016
- 378
I was thinking of using a AC servo motor the ram on the actual shaper not on the proof of concept model. The real machine would use a multi start high lead screw for the ram, just as the XM-1 ( the screw on the XM-1 was about 3" diameter from my modeling) Hear is my thinking on basic use of the machine, jog to the starting point (as you mentioned .75") set zero on the encoder/controller, jog to the stop point (the encoder has been counting the turns of the motor or screw all this time) set the stop point, control would remember this count value. Now the controller would oscillate between these two values, when the controller is reaching these values it would decelerate before changing directions. When at the zero/home count the controller would then output signal to the other axis motors, before starting the ram again. The M66 sound like it would work when the counter reaches zero count if I understand what you are saying?
