- Feb 8, 2014
- 11,151
That is what I am talking about. It does not say each division equals .0005" of movement. it says it is axis offset, what ever that means. offset from what and where.
Mark, that is the offset from the center of the hole (or pin) to the spindle centerline. Normally in use you don't worry about actual dimensions, just adjust X-Y position for minimum needle movement when centering on a part.
