I have had a Smithy 12x36 lathe for a couple of years, having stepped up from my first lathe, a 3-in-1. Also have a Jet round column mill.
I'd like to put a collet system on the lathe. I have a 5MT to 3MT adapter, a set of ER25 collets with an R-8 adapter I use in the mill and am wondering what the best way to go for the lathe. There are 5C collet chucks available online for not too unreasonable prices that fit the D1-4 check mount in the lathe. I obviously could get/make a MT3 adapter for the ER25 collets or go the opposite route with a 5C collet setup.
I don't have any real need at the moment for the collet system. On the other hand, I do a little bit of gunsmithing on the lathe and a lot of rifle and pistol reloading so the need for smaller diameter parts pops up every now and then.
So, I am wondering if the 5C approach is worth the investment or the ER approach will work for me. I also am a little fuzzy on the collet closer. I get the drawbar system for the ER adapter and collet chuck and sort of get the 5C system. However I see these complicated (and expensive) 5C collet closers for sale that seem to be sort of an articulated drawbar of sorts. I also see simple drawbars with the internal thread 5C on one end and a knob on the other. I have found tubing with the internal 5C threads on one end, presumably these are for home brew closers. Not a lot of specifics on Ebay or here on 5C basics whenI do a search.
Would appreciate any and all opinions, comments, and suggestions on the best way to proceed, Thank sin advance for the help.
Steve in Central TX
Steve in Central TX
