I am adapting a change gear setup to fit my 1946 Leblond. In the picture below I am mocking up the fitment of the gears so that I can create some spacers to align the gears properly.
My question revolves around the compound gears and the spacing of the 2 gears that actually run next to each other. As you can see in the picture below the hub of the bottom gear is slightly longer leaving a small gap.
Should I leave the gap so that the gears do not rub on their sides or turn down the hub so that they are closer together? I haven't measured it but the gap is around 3/32 to 1/8". The gears are 1/2 wide.
