- Feb 27, 2014
- 2,129
Sometime back I replaced the tank on my compressor and in existing copper pipe would no longer work. At the time I replaced it with a 24" hydraulic hose that had NTP Female NPT on one end and something else on the other that would "spin" to allow me to tighten the connection. This mostly worked but the end that "spun" was not really correct and over time it leaked and the leak is now bad enough that I want to replace it. Here is where I could use some HELP. I mostly understand basic NPT fittings and in my case the compressor has 3/4" FNPT and the tank is 3/4" FNPT. I also have a nice hose with 3/4" MNPT threads on both ends. What is the fitting type that I need that "spin" so I can install the hose? This has to be common and easy, right? but l just can't seem to find the right part to search for. It would need to be something that will go on the MNPT threads on the hose and the FNPT threads on the tank and be able to be tightened without spinning the hose.
