- Nov 21, 2023
- 10
Need guidance on where load , common and ground wires connect in control panel on a Enco 110-2079lathe . Lathe currently has no power connected. Any help would be appreciated
I’m going with 110, motor was already wired for 110 . Just has no power wires to control panel yet.Are you going to use 110v or 220v ?
I understand that load wires go to R and S but with 110 I only have three wires with only one of them being a load wire so I’m a bit confused how it should be wired.I’m going with 110, motor was already wired for 110 . Just has no power wires to control panel yet.
Ok , what do I do with the common (white wire )?the load wire should be black
The R terminal gets the load wire
As a point of information, it doesn’t matter what polarity you choose for this control panel, it will work exactly the same
Mine currently has a blue wire ( z2 ) coming from the motor to the 3rd terminal .Green to the 3rd terminal
