- Feb 5, 2014
- 43
I have been kicking this idea around for some time. Here are the details: By removing the cylinder and barrel from a Colt cap and ball revolver and replacing them with a unit that slips over the mandrel and securing it with a colt pistol wedge, with the upper assembly threaded for whatever size barrel that it is possible to use such as 32, or 36, or 40, or 45 caliber, with a percussion nipple... I believe that a Small Game hunting Pistol would be quite possible to construct and it would be simple to switch back to revolver mode in only a moment. The bore of the cylinder is very close to the center mandrel, but by raising the center line of the accessory barrel, any number of barrel combinations could be possible. Also by aligning the nipple with the hammer in a higher position than where the hammer normally engages the nipples on the cylinder the barrel could be positioned with a higher sighting plane. My dear Machining Experts I would appreciate any input on this idea that you may have.
