It was a CL find one hour after posting , chopper shop 5 min away moved into smaller shop and didn't have room for it. Has very little use on it belts look new ,inside cover looks new , with the superchuck on it I'm getting .0007 on a 1/2" dowell he wanted $100. But took $75. Tightened up the quill housing with the adjuster on the front , never seen one like that.
I had to smooth out the swivel boss a little and shim .004 in lower portion to get .0005 8" around square to spindle, motor pulley was loose and up 1.5" to high, pushed that down and actually tightened the set screw as it was loose . table and DP are better than new now.
Polked a 1.5" Deming drill thru 1/4" steel plate without a hiccup at220 rpm.
