- Feb 1, 2015
- 9,623
Like Jim above, I have had poor success with big box single flute countersinks. And like Liljoebrshooter, I will often turn the power off and manually turn the spindle by hand.
I have that same unicam fixture, and it does work, but is not really easy to use, I prefer my Weldon countersink fixture, especially if I have a bunch of them to sharpen.I've used the single flute almost exclusively for over 35 years. On occasion in the field I've used 6 flute, but they're best when used in a rigid setup like a mill or lathe. The 2 brands I have in the shop are MA Ford and Keo. I bought he MA Ford set in the mid 1980's. They've been used to countersink and deburr thousands of holes in 316 stainless, 6061 aluminum, 1018 and all sorts of other alloys. I highly recommend both brands.
We used MA Ford exclusively in the shop at work and never had any problems. Mine have only been sharpened once in all that time. It's getting near the time to sharpen them a second time. To do the job I bought a MA Ford Unicam sharpening fixture like this about 15 years ago:
At the time I paid less than $50.00 for it. I see the price has gone up a bit since then
One trick i figured out with my very low quality drill press for using a countersink is to turn the power off and turn the spindle by hand. I just pull the feed lever down and twist the spindle with my left hand. It only takes a couple revolutions. And no chatter.
The zero flute ones almost eliminate this.
Joe
