Craig's List Walker Turner DP
Measuring from the center of the chuck back to the. Column it measures 10" which would seem to indicate a 20" drill press I believe. It also has a 1 HP motor. Does anyone know where the model number might be located?
I'm new here also, Yeah that's a 20" 1100 series !
I picked up two of them from C/L over a year ago for $75
I also couldn't find any part numbers on them & the serial#/ID plates were the same?
Here's my latest stage of restoring the WT
I still need to install new bearings, WT used odd sized bearings!
You either need to get lucky & find some on E-Bay (which are usually expensive) or machine the spindle down about .009" to get standard 5205 bearing to fit.
Doug
