- May 27, 2016
- 3,480
My word for lesser quality items.
Sure, it was a piece of one of those carbon steel tap and die "sets" you can pick up in DIY stores, or even shopping at ASDA, but it did not have to do much! A basin tap fitting thread anchor. Access was too limited for the over-long zinc-flashed M8 stud, so I decided to re-purpose a Allen head M8 bolt by extending it's threads a cm or so (that's about a half-inch), and cutting it off. Given where it was being used, the donor M8 was to be from Britain's finest stainless. Truthfully, it might have been China finest - I don't really know.
Any-Hoo, the business of die-cutting M8 A2 stainless was always going to be a bit fraught. WD40, the only handy cutting oil. The bolt probably had it's threads rolled on. Whatever.. it was damn tough stuff! Even so, I went slow, 10° or 20° at a time with lots of chips clearing and squirts of WD, and getting a work-out on it.
The hand bars are coarse threaded, and a sloppy fit, and too thin for working up heat on a M8. Still - slowly getting there. The thin bars hurt, so I shoved some small hosepipe over them. Why is it that the dimple-anchor screw has to be re-tightened every minute or so?
So..
The thin bars bend at the root. The housing lets go in a failure mode that can leave one with skinned knuckles, but lucky I had the nitrile gloves. Trying to encourage even a final half-turn and a threads clean-up fractured the other bar collar as well. There did follow, some Anglo-Saxon expressions of a robust and unseemly nature!
Fortunately, I had another "set". ToolZone from the Aldi store center aisle. This set was dedicated to dies in inches, but the die holder is marked 25mm and also 1". The die did "fit", as well as these things ever do.
I know HSS steel is better, and Cobalt is best, but I long for a classier, stronger, more comfortable holder with handles that don't bend at the root before breaking the die!
So..
