- Mar 15, 2019
- 708
Check tips or cutting edge/s of the tool and follow the cutting specification of the material to be machine.View attachment 301876
I can't feel the swirls with fingernails. Before the cutter swept on the trailing side it was mirror like and then the trailing cut made the marks. Material is 6061. I'm thinking more radius on cutting edge and a touch slower on the manual feed.
Yep....team looks spot on.View attachment 301876
Interesting post. I've actually been on the verge of posting a thread on this same subject. I made a fly cutter a few months ago that was a very good learning experience and turned out quite well (see photos below). But I have noticed a curious phenomenon that I, too, have wondered about. My fly cutter will mill about a 4 1/4" diameter. I've used it on both steel and aluminum and have noticed a consistent result: When I am feeding FROM the right - that is cutting the left side of the work piece first, the finish is beautiful. But when I feed from the other direction, I get a result similar to the photo shown above - not nearly as extreme, but the trailing swirl marks are visible. I am certain that my mill is correctly trammed. I am feeding at a very slow rate with an RPM of about 800 - 1,000 on 6061. (Played around with both feed rate and RPM's with no appreciable difference in results.) I wonder if perhaps because of the weight of the tool (it's pretty hefty), centrifugal force may be playing into the equation in one direction. I've accommodated for this by always feeding in one direction with very good results, but that seems a little like cheating. Any thoughts from our experts?View attachment 301876
That is very sharp looking. I ended up with something very similar after doing a couple with the angle. It works very well.Interesting post. I've actually been on the verge of posting a thread on this same subject. I made a fly cutter a few months ago that was a very good learning experience and turned out quite well (see photos below). But I have noticed a curious phenomenon that I, too, have wondered about. My fly cutter will mill about a 4 1/4" diameter. I've used it on both steel and aluminum and have noticed a consistent result: When I am feeding FROM the right - that is cutting the left side of the work piece first, the finish is beautiful. But when I feed from the other direction, I get a result similar to the photo shown above - not nearly as extreme, but the trailing swirl marks are visible. I am certain that my mill is correctly trammed. I am feeding at a very slow rate with an RPM of about 800 - 1,000 on 6061. (Played around with both feed rate and RPM's with no appreciable difference in results.) I wonder if perhaps because of the weight of the tool (it's pretty hefty), centrifugal force may be playing into the equation in one direction. I've accommodated for this by always feeding in one direction with very good results, but that seems a little like cheating. Any thoughts from our experts?
(Sorry, no pix of the result. That's why I haven't posted yet. The photo on the original post is similar, but not nearly as extreme.)
Regards,
Terry
View attachment 304974View attachment 304975
