Custom Gravely Mower Deck
dave
May 28, 2011
37
Another one of my odd ball projects
I got a Gravely pro walk behind mower with a rotted out mower deck
being some what creative and having to many tools and time
I custom made the entire deck out of 3/16" diamond plate
dave
May 28, 2011
37
I think your rite Bill
But at least my son will have a tank of a mower
It's a shame when some one like Gravely cheeps out and uses stamped sheet metal for the deck
I don't think the deck will be a problem any more
RandyM
H-M Supporter - Gold Member
Apr 12, 2011
3,228
Holy smoke, nice job. That thing has to be twice as heavy? Sure would like to see it all mounted up. ;)
M
"Mike"
Forum Guest
Register Today
I'd have to use the engine hoist just to mount it!
dave
May 28, 2011
37
It's actually not as heavy as it looks
The original deck had a 3/8" stiffener plate bolted to it so it only about 30 lbs heavier
And a little extra weight helps offset the hydro drive , battery and the hydro fluid reservoir
it needs to be repainted again after adding the mount brackets and a baffle underneath
It will be on the front burner pretty soon the push mower is getting old !!
chief
Dec 4, 2011
104
That deck would look good on my 1951 farmall
chief
Dec 4, 2011
104
His name is Jerry lea, and a good watch dog,
chief
Dec 4, 2011
104
Here is my other tractor Ferguson TO-30
rafe
Aug 20, 2011
527
I picked up a yanmar tiller (3pt) that someone had destroyed the outboard bearing and continued to run it....it was so loose the tines ate the sheet metal badly, they then repaired it with a loose bushing and a shim....I guess it worked but it rounded off the shaft end. I was able to install a bearing and custom make a race to keep it in place ....I removed the
damaged sheetmetal and welded perforated steel in its place ...the best part was that all the parts were already here
AdBlock Detected
I've Disabled AdBlock
