- Jan 28, 2011
- 3,496
Decided to post some of the photos from a build I did back in 1990-91. I was encouraged due to mickri's topic Headers for my MG Midget.
These were based upon many articles in Hot Rod, Popular Hot Rod, Car craft etc.
Had 1/2" header flanges cut and with 3-4 boxes of u bend tubing, alot of try and fit and repeat over a couple of months on my spare time. Used a spare 2.8 for mock up with on the weekends remove the exhaust from the car to try and make any changes required. I got really good at remove and install the factory exhaust. Had to move the DIS from below the exhaust manifold to above the rocker cover for room. A slight reshape of one of the cooling fan legs for clearance and diverting a water line was what was needed for the front set. The rear set there was actually more room but not for traditional long tubes. Had to twist them around like a french horn so that they would meet up at the collector. 1-1/2" tubing with 3" collector feeding into a modified cat with 3" SS pipe to the rear of the car. The car would still pass emissions, but barely. Even at at the end of its life the headers were still on the car and I removed them and sold them to another guy. He could use them to pattern another set for himself.
Pierre
Pierre
