- May 14, 2015
- 179
I'm playing with the PM1228VF lathe now that I have a few hours free (my measuring devices haven't arrived just yet, so mostly just making a mess and checking everything for basic function & familiarity). I have noticed a very strange, persistent behavior of the cutter that I haven't heard reference to before in my many hours of online research into lathery. Every 1/8" --every turn of the feed rod-- there is a smooth wave a couple thousandths or so deep. No matter what spindle speed, no matter what gear selection (I did fastest and slowest and the result was the same) there are these sinusoidal variations. They aren't spirals, but rings.
I have two theories, kind a of chicken/egg situation as to which might be the culprit here. The first is that the apron gear driven by the feed rod is oblong, and lifting/shifting the carriage as the high spot swings around, affecting the cut. The second is that the headstock gears driving the feed rod are tight at some point in their rotation, and this bogs the motor down subtly enough to affect the cut (this seems less likely, but there is a slight variation in RPMs every few seconds as the feed rod rotates, whether by cut depth or gear train)
Searches for the title I've chosen and pertinent key words are coming up a goose egg, so I thought I'd try here for advice. While I don't have measuring tools just yet, I can clearly track a paint dot on the feed rod, and it always sits in the same spot relative to the peak of the ridges being cut, so it's not just a frequency thing, but a feed-rod position correlation. Oh yeah, running the lead screw for a cut does not appear to leave the same ridges (harder to tell with threads, though)
TCB
TCB
