Yes, usually. My 13x40 is missing a combination for 27 TPI as delivered, but 8 and 11-1/2 TPI is no problem. You will need to deal with the taper, 3/4" per foot. You can use a taper attachment, if you are fortunate enough to have one. You can offset the tailstock if it moves far enough for the length of the part. You can use a tap or die driven by the lathe. You can use a jaw out of a pipe threader as a form tool to taper the threads. I happen to have one in 8 TPI.
