Dayton Mill /drill Rong Fu ??
lo7us
Nov 3, 2014
18
I have a Dayton Mill Drill I recently acquired and added (3) DRO's, but can not find which Rong Fu model it is cloned from... any help would be appreciated. 01fd6e3dcc6f39f06ff8f3a5b154a782fbb0b019cc.jpg
RF25/RF30/RF31. What Dayton model # is it?
Looks a lot like the Jet 15 that I have which is an RF 30 Clone.
The easiest way to figure it out is to take some measurements and compare.
Start with Table Dimensions
X & Y Travel Distances
Quill to column.
The Grizzly g0705 and Jet 15 are both the same just re-branded with some Mfg specific details.
Google up their sites and compare spec's
Both will let you download the Op manuals and they will help you figure it out.
Quill to column.
The table is 9.5 (X) by 32.5 (Y) made in Taiwan
Item Milling/Drilling Machine
Swing (In.) 16
Motor HP 1.5
Phase 1
Voltage 115/230
Hz 60
RPM 1725
Chuck Size (In.) 5/8
Spindle R8
Spindle Taper J3
Spindle Speeds (12) 120 to 2500 RPM
Spindle Travel (In.) 5 In
Spindle to Table (In.) 18
Column Dia. (In.) 4 1/2
Quill Dia. (In.) 3
Head Milling, Swivels 360 Degrees and Travels Vertically by Rack and Pinion
Table Work Surface (In.) 31 7/8 x 9 3/8
Table Surface Height (In.) 10 1/2
T-Slots (4) 5/8 In
Graduations (In.) 0.001
Capacity Drill 1 1/4 In, Face Mill 3 In, End Mill 3/4 In
Features Dovetail Ways With Adjustable Gibs, Adjustable Depth Stop
Operation Table Rotates 0.100 In For Every Turn of Handwheel, Maximum X-Axis Travel is 19 3/4 In, Maximum Y-Axis Travel is 7 In
Includes 3 Inches Face Cutter with Arbor, Chuck Key, Work Light
