This is a low rpm motor. The gear is not plastic. The coil appears good, but I think it's bad.
There is no electronic, just brushes and commutator.
It stopped working and if I spin it, it will run.
Usually, a start capacitor is used in AC motor to start a motor.
For this, I can only think one of the 3 windings burnt out and it no longer pushes at particular angle.
I don't think this can be saved, unless someone gives some idea. This about $12, and it's not easy to take apart (no screw, just punched into the case). I probably just save the gear part.
