Parts made in a brake normally can't be deeper than they are wide because the part hits on the brake. I needed thirty fence insulator yokes and came up with this neat fixture to bend the metal on the press brake. Thought i'd share this clever trick.
This is brilliant. I had found an idea online (sorry can't remember the source) that I was going to do. See pictures. But I think a version of what you made will be much better and I don't have to tap holes in the breaks table.
