- Oct 31, 2016
- 2,645
I picked up on older Delta belt sander over the holidays. $40. Another estate sale find. It came with 320 grit, 100 grit and 24 grit belts. The 100 and 24 grit belts need to be glued together. Is this typical for belt sander belts? Also included was the original owners manual and parts list. The bearings in one of the wheels is a little noisy. How do you or can you lubricate the bearings. No mention of lubricating the bearings in the owners manual. I bought some 80 grit belts at Ace. The platen is very solid. There is a support arm that you can put against platen to keep if from flexing. Was not hard to adjust the angle on the table. It needs a switch in the power cord. Right now you plug it in and it runs. Runs smooth. No vibration and the belt tracked nicely on the wheels.
The only negative is the tires on the wheels. The tires are some kind of plastic glued to the wheels and are cracked with a piece missing on one wheel. You can buy replacement wheels but they are expensive. I am thinking about using a bicycle inner to make new tires. Any other suggestions?
I have no place to put this in my garage. It will sit on one of my workbenches for now. A major reorganization of the garage appears to be necessary.
