- Nov 14, 2016
- 3,041
Tractor Supply has two Dewalt air compressors 25% off for Black Friday (through 11/28) which makes the prices quite appealing.
Tractor Supply Dewalt compressors
30 gallon portable 1.6hp 5.3cfm @ 90psi, max 155 psi, belt driven V-twin oil lubricated pump. 75dB Sale price $375
60 gallon stationary 3.7hp 11.5cfm @ 90psi, max 155psi, belt driven inline 2 cylinder oil lubricated pump. 80 dB Sale price $419
I've got a little 6 gallon pancake compressor 2.6cfm @ 90psi that has been doing the job, but I've been eyeing something bigger for quite some time. I was considering a California air tools 2 hp, but this 30 gallon Dewalt is almost 1/2 the price, same performance and only 5 dB louder (which I know is like 1/2 again as loud). The stationary of course blows them both away, but will be a much bigger headache to get into place, and will require running lines vs wheeling it over. Still at 200lbs the stationary is light enough that I could get it into place.
My biggest concern is the oil lubed, is this an issue? Seems like most of the higher end are oil less these days.
Are these decent light duty compressors or am likely to regret getting one? If I've been getting away with a 6 gallon pancake which I think tells you the kinds of demands I put on air in the shop.
