How do you adjust the stem angle on a dial test indicator?
H HarryJ Registered Registered Joined Mar 9, 2021 Messages 18 Aug 29, 2021 #1 How do you adjust the stem angle on a dial test indicator?
pacifica RGL H-M Supporter Gold Member Joined Jan 2, 2018 Messages 586 Aug 29, 2021 #2 HarryJ said: How do you adjust the stem angle on a dial test indicator? Click to expand... On my compac and interapid you just push it to the angle you want. There is some resistance-maybe around 5 lbs of pressure.
SLK001 Registered Registered Joined Mar 21, 2018 Messages 1,597 Aug 29, 2021 #3 Usually, it's with the mounting lug on the back of the DTI. The DTI must be perpendicular to your measurement.
S soniamann Newbie Former Member Joined Aug 27, 2021 Messages 10 Sep 2, 2021 #4 When I started this, I thought it would be easier...
X xr650rRider H-M Supporter - Silver Member H-M Supporter - Silver Member Joined Feb 20, 2019 Messages 335 Sep 2, 2021 #5 soniamann said: When I started this, I thought it would be easier... Click to expand... For the majority of them it is. Use your fingers and move it. Just that simple.
