If you are using a surface grinder, most people who are dressing only the OD make a little block that will stick to the mag chuck and in the block, have a hole with a set screw to suit the shank of the dressing point. Run the head down to barely touch the wheel, with it running, and the wheel roughly centered over the point. Dial in and out across the face of the wheel, lowering the wheel a little at a time until running true. Light touch is key.
